problem is, i am a shitty mechanic
i dont even know what the auto wiring is , let alone the neutral trigger.
Well keep it all connected to the auto box find wiring for the selector on the gearbox and make sure it’s in the neutral position you should be able to take the selector off the gearbox and just change it between gears. Just look on your dash to see which gear is selected to work it out.
ok, i am about to start my swap in a few days.
I am 2 weeks of and i have planned to use those two weeks for the swap.
Somewhere i read that by using the charade ecu, it will be running rich?
So i want to use the applause ecu, i mean the engine came with it, seems best to keep using it.
Is there a way to get rid of the immobilizer?
p.s: i know the charade has a higher rev limiter, but that is of no interest for me, i am not building a racer
Nice
