I’m looking into getting AVID1 AV8 15 x 6.5 +35 offset wheels with Federal SS595 195 45R15 tires. My charade is lowered by about 1.4 inches and its camber is able to be adjusted by 3 degrees +/-. Everyone I’ve talked to is only worried about the offset on the rear rubbing on the fender skirt, so I was wondering if anyone knows if 35 offset wheels will fit without rubbing?
Mate I put 235 /14 on one I used to own & had to lip the guards hope this gives you some indication as to what clearance you will need.
