Sirion 2 ABS
Hi everyone,
I need help with the ABS in my Sirion 2.
Here’s my story: It started with errors 15 and 24. So, I replaced the rear left wheel hub, cleaned the terminal plug, and reconnected it. I also cleaned the plug on the ABS actuator and checked the two wires leading to the rear left wheel – everything was fine. Happy with the results, I started the engine and went for a short drive. The ABS was working.
However, after 24 hours, the ABS failed again. Now I have errors 24, 84, and 88. I tried to adapt/reset the ABS system according to the manual, but it didn’t work. (Reseting error with bramkę swith, later driwninf with slow speed on error 81-84 and later 10-40kmh on error 85-88 but nothing)
Does anyone know what might be wrong?
I also turn off my battery for 4h but it’s still looking on broke.
Hi LukLan,
I am sure there is someone here that will help. We do get a lot of people pop in for free advice. They get their solution and are gone never to be heard from again. To increase the chances of finding help from the Dai family posting an introduction and a pic of your Dai can really help. If you invest in the forum even a tiny bit by posting in the new people section it inspire help I am sure.
With.the cuore 251/sirion2/materia.the abs rings on the hubs could be rusted they are seperate units can be replaced
