Springs for L200
looking for all 4 springs for a 94 l200 Mira as mine is currently sitting on chopped springs.
Ive been told that you can use L5 L6 and L7 springs, just wanna see if anyone can confirm before i buy a set.
Not much fun ridding around on bump stops. L5 and L6 will fit. L7 (I think from my vague memory) are a lot taller. If buying go with L5. Std front rate will give good grip. Std rear rate will understeer. Get the highest rate rear you are game to go. The stiffer the rear the better it will steer/turn.
Yeah my spine does not approve of the chopped springs haha, cheers for the info man.
i guess another question i should have asked is where do you recommend buying spring from?
Yes they will fit as I am theone that told you lol
