Tacho wire on smiley face charade
Ok so i just installed a microtech and runs fine just trying to figure out where that tacho wire is in the engine bay to make the tacho work, any hel would be great.
The starlet and corollas run off the dizzy.
Possibly the same. Toyota don’t change too much.
or try the coil.
Alot don’t have them so i had to use a wire from negative side of coil for a dash conversion.
My car already has the dash with it just need the wored that goes to the dash to connect it
Negative side of coil then to where it says TMP on dash, check out my dash conversion write up on here :slight_smile:
