Looking at getting a Terios J100 or J102 and would like to know what, if any mods there are to increase the low down torque to aid the off roading.
Here is what I have deciphered so far:
The J100 has an ‘H’ series engine, as does the Sportrak (Feroza) would, by fluke the 1600 go into the Terios without a fight?
The J102 had a limited run with the K3-VET, which is also found in the YRV Turbo - with the Terios having a longitudinal layout and the YRV having a transverse layout would this cause issues putting the YRV lump into the Terios? There is of course the issue of the YRV Turbo being auto only and me being a strictly 3-pedal kind of guy.
I also thought of putting the YRV Turbo bits onto the Terios engine (with a thicker head gasket to reduce compression ratio) which may be the simplest route.
What are peoples thoughts?
