Track Day GTVi - South Australia
Sparkplugs:
Cyl #3 looks to be the primary culprit. Will try some of the internet mystery fixes of soaking the piston tops with a variety of solvents (Marvel Mystery Oil if you’re in the US, otherwise some kero/deisel here) to see if that helps at all. Otherwise i’ll tough it out until I do something about rebuilding it.
Fusebox Relocation:
Bracket was cut in half and re-bolted to the strut tower to orient the fuse box this way. A bit tight to the wiper motor…but another way to look at it is that it helps hold it in place :slight_smile:
