Hi Daifam, no longer needing. Made it for the IDF manifold but I cut it up to make a supercharger manifold. Long story short, made from 304 stainless steel, steel AN fittings with Speedflow 3/8" 410 series fittings, 4 mm barbed fittings are 304 stainless steel, even the thread adapter for the 10mm brass barb is 304 stainless steel.
Ceramic coated in Cerakote satin black.
$40 including postage Australia wide.
Cheap because I would rather see it go to use then end up in the bin.
