Want to buy an oil cap (plug style) from a cb24. 3cyl carby. And also the steering column plastic cover, and air vents if they don’t break. Located Logan/Brisbane.
I did see the oil caps on ebay ages ago maybe they are still there? In the meantime I have seen some poeple put electrical tape around them to help seal them in and stay on as a temporary solution. Maybe worth a shot?
I’ve been searching everywhere, on eBay and even in shops. The closest I found was a ‘Tridon, push style cap’, but the only problem is I would have to modify it and put a breather filter on it and then block off the vacuum hose that goes to the intake/carby.
I did see this one good idea that involved a flat piece of thin sheet metal, and it had a half circle cut out and it held the cap down, but I’d rather try and find another cap. It must be a common thing for them to have a broken piece, as I believe people don’t realise that it’s a twist quarter to half rotation and then pull up
. Here’s what mine looks like.Can’t pinch one from some other make? Looks similar to a toyota one I’ve seen
Yes I probably can actually, I just realised that the G100’s also have the same oil cap.
Just got to think laterally
Been there and done that so glad to pass knowledge along. You can pretty much throw any problem at me and I usually have a reasonable idea for the problem
Or happy to help
