WANTED: L200 5sp gearbox
Needing a L200 5speed gearbox brisbane please.
bump.
bump.
bump
I have a few. But would need to assemble one for you. What is wrong with the box you have? Or do you not have one?
I just want a box to rebuild as my current one the bearings are starting to get loud and its getting harder to slot into gear as the bearings start to collapse. and i want it so i can just do the swap in a day as its my only car.
I’d have one that has the main shaft assembled and just needs this, the secondary shaft, diff and shift forks reassembled. Benefit is you could inspect. $50 pick up Mt Tamborine.
