What are the common problems with Daihatsu Sirion's Model:M100
Hi All,
Just wondering What are the most common problems with Daihatsu Sirion’s Model:M100
My 1999 Daihatsu Sirion currently has noisy wheel bearings and the steering (no power sterring) seems to be pretty stuff. Could this be to worn bearings? tyre pressure? etc?
Also has a problem put up electric windows on drivers side,I was told its the master control switch?
Cheers
Any noise in wheel bearings needs to be seen to as soon as possible, especially if driven for a distance or at speed, power window switch is pretty common from what others have said :frowning:
