Hi, does anyone know which ecu this is?
Its Running a k3 swap in a cuore
Copen 2009 or Terios late.
Not ve2 though I don’t think.
Def 1.3.
Thanks mate!
So i found this thread here:
I am looking for the REV, Motor Speed Sensor/Signal in this ECU i have posted earlier.
How do i know which port is for this signal? I have to connect the signal from the speedo cluster to the ecu, because I got the fault code that this signal is missing.
Thanks!
negative coil will give you the rpm signal
And Where do i have to Pin it in the ecu?
in the k3 ecu or the ed20 ecu? in the ed20 I didn’t and used neg coil as i said. K3 no idea.
