Wheel Size
what is theoretically the smallest wheel i could fit on a l200 mira? 12" is factory but could 10" / 11" clear the brakes?
I believe 10’s can be done but you have to downgrade your brakes to drum from an L60 from memory.
There was a member on the orig forum running 165/60/10. Rode terribly, couldn’t get into a lot of drive ways or get over speed bumps and pretty much had no brakes, sure it looked a bit different.
