Who Wants TEIN To Make High.Tech & EnduraPro PLUS For Our Cars?
Anyone’s interested in a sporty yet comfortable suspension set up that’s daily friendly for their Daihatsu Sirion/Toyota Passo/Perodua Myvi M300 & M600? (Both M300 & M600 platforms share the same spring & shock)
I’m interested in buying the TEIN High.Tech lowering springs (Progressive, has Silencer Rubber) & TEIN EnduraPro PLUS adjustable shock (16 lvl adjustable damping Twin Tube damper with Hydraulic Bump Stop, & behaves like it has Digressive Valving) with Advance M.S.V.⁣
But TEIN doesn’t make them for Sirion unless they see a minimum order quantity of 50-100. If anyone’s interested, feel free to fill this up & let TEIN know (& tell them it’s for Daihatsu Sirion/Toyota Passo/Perodua Myvi M300 & M600 so they can see that 1 product can fit many different cars):⁣⁣⁣
https://www.tein.co.jp/cgi_e/contact.php⁣
For those who’re interested in adjusting their damping from the cockpit instead of doing manual adjustments, TEIN has a wireless control system for the EnduraPro PLUS too called EDFC Active Pro.⁣
It’s probably the best daily friendly yet sporty setup I’ve come across for street use & mild to moderate tracking.
I moved the topic from build projects to Question’s and Answers as it is not a build project but a question for member’s.
thanks! i wasn’t sure which category i should post under initially. will keep that in mind!
