Hey all,
Just a quick question, does anyone know if the camber bolts that will fit a M1 sirion also fit a M3 sirion? I tried searching but wasn’t able to find camber bolts for the M3. But since allot of Daihatsu parts are interchangeable I would figure this wouldn’t be a problem. I hope that someone can confirm or denie this. Thanks in advance!
if your could give me a measurement of the width of the steering knuckle (so basically the length the bolt needs to be) on your M3, I can compare it to the sizes of the Cuore’s knuckles! I know @Roffelkut uses camber bolt, so they definitely fit on those knuckles
Okay so I finally managed to get a somewhat accurate measurement (I really love working on lowered cars you know?). It seems that the bolt needs to be around 3 cm in length (that’s between the plates where the bolt goes through connecting the strut to the hub). Around 5 cm length in total inlcuding the nut and face(?) of the bolt.
I measured a bolt today which was around 6cm, but wasn’t able to measure the knuckle or anything else, so it was kind of useless.
But then I came up with the idea to just look for the partnumber of the bolt, and they seem to use exactly the same units
I hope this helps, otherwise I can do some more measurements tomorrow
I’ll take the gamble. Thanks ![:slight_smile: :slight_smile:](https://livetodai.com/images/emoji/google/slight_smile.png?v=12)
Where did you get the part numbers from? I tried searching but never did get the right site.
