Wiper motor relay -Applause
Hi,
Anyone know where the wiper motor relay is located in a RH drive 1996 A101 Applause ?
I’m guessing it’s the relay that’s causing my wipers to stay on regardless of switch position.
Thx
Fuse box - 1 lamp relay only.
Another separate lamp relay near the brake pedal, but no wiper relay here.
The glove box on the other side of the dash may hide the relay, but I haven’t been able to remove the glove box without pulling most of the dash out ! There must be a trick to it.
This may not help at all for your car, but give it a try. I could not find my horn relay in YRV (2001) either - and posted a question here couple of weeks ago. Horn relay woes YRV - #3 by arnold6 It turned out the relays for wiper and horn were soldered to the wiper/light/indicator stalk switch assembly, so I had to take out the steering wheel and clock spring unit out to access it. If you can download wiring diagram (I had, from Daihatsu Club Net), it will confirm where the relay is located. Not sure how to upload picture on this site. . .
