YRV 1.5 Turbo /3sz-T
Hello
I am From chile and this is my daily car :smiley:
Specs :
3sz 2008 75.000 kms
Intake and throther 3sz
exhaust and intercooler K3-VET
Turbo IHI VF33 of a subaru , hibrid whit VQ41 exhaust case.
Flywheel less 500 gr
injectors 425cc RX8 denso
Manual Gearbox whit 4ft gear of a Mira L700 (1:1)
Eliminated A/C and pulley extras.
The cranking wheel is by K3VET and ECU P30 Japanese market 1 Bar of Bost TOP
i only charging a 0.4 Bar and run more fast of a K3 whit 1.2 Bar.
interior
Turbo VF33
Cañerias a medida y bomba hidraulica relocalizada
Engine Internals:
Stock:
3sz from toyota avanza FFR
from chile whit love!
Amazing!
Hello and welcome to the forum
Hello, welcome!
This conversion is interesting to see, does it mean i can swap a 3sz-ve engine in my cuore l701?? It has the front and rear mount for the engine frame??
Welcome, great car. Fantastic, write up. Looking forward to hearing more.
Yes you can. Just use the mounting from K3-VET.
Here is my Perodua Kelisa a.k.a Cuore L7 3SZ swap.
anyway great build @Speedpower. But just take into consideration, stock 3SZ rod can only hold up a maximum 0.5 bar of boost. More than that, you know what will happen. Happened a lot to most of my friend. They successfully carve a hole on the block.
Hey man, great build!
You said you used the 4th gear from a Mira. Can you just swap the gears or shafts like that? I would like to know how you did it!
Cheers!
