Daihatsu Charade 3-door G102 TX
I N T R O D U C T I O N _ &_ B A C K G R O U N D_ I N F O R M A T I O N
07th June 2021
Hello,
i am Leo, 30y/o & located in germany, so please forgive me if my english is not the best.
About five weeks ago, i bought my second Daihatsu:
a Charade TX 1.3i w/ 90hp and front wheel drive from 1991.
My first Daihatsu - and my first own car ever - was a Daihatsu Cuore L7 from 2003 w/ EJ-VE engine. I loved that Gokart-Feeling but the engine said no last year. After i bought a slow-and-unfunny-as-hell-to-drive Honda Jazz for daily use, i wanted a new Cuore. So enough of my car history and back to topic:
after a lot of searching i found an offer in a german Daihatsu group on facebook:
a white Daihatsu Charade 1.3 TX from 1991, as the name says, 1.3l-engine, front wheel drive, 90hp, 111.000km on the clock, not running at all. 90hp at an empty weight of 695kg or so (i think), that sounds funny.
A little to the background of this car as far is i know:
before me, there were two owners. the first bought it in 1991, added new wheels in 15" and installed lowering springs (-30mm). He also swapped the driver’s seat for a Recaro Idealsitz. He only used this car as his second one and, after the death of his wife, the charade wasn’t used for around 9 years.
The second one bought it one year ago or so and changed the fuel pump which died after 9 years standing around (in a garage). So he only changed the pump & only has driven this car to his garage.
The fuel pump died again (so he said) & so he decided to sell it, Luckily to me.
S P E C S & S T A T U S __A T__B E G I N N I N G
  • Building Year 1991
  • FWD
  • 1.3i, 90hp
  • Rims: EXIP 7x15 / tyres: front 195/50, rear 185/55 w/ 3mm spacers each side
  • Recaro drivers seat
  • lowered by 30mm w/ lowering springs from 1987 (manufacturer: Auchter + Beck)
Backgrund information: Auchter + Beck was a very popular german company for daihatsu tuning, very popular was the Daihatsu Charade FLASH, which was a bodykit for the Charade GTti w/ 9x15 rims
  • Battery dead, fuel pump dead (doesn’t make one single noise when i try to start the car)
  • timing belt was already changed 22.000km (and 22 years) ago.
the engine cranks and, if we spray break cleaner into the air filter box, starts.
185/55R15 on the rear, with 3mm spacers each side & lowering by 30mm (at least). fits barely.
Engine bay
Here are some pictures of the interieur & outside of this car. For 30years it doesn’t look to bad imho.
First we demounted the wheels to have a look on the springs. My hope was that they were in not too bad condition, because they are no more lowering springs from Auchter + Beck.
Side Note: in germany, nearly all aftermarket parts you want to install in/on your car need to be TÜV-approved (equivalent to MOT test or whatever it is called exactly). They have to be testet for security with a certificate and so on…
Auchter + Beck are no more, and Mr. Auchter told me he has thrown away the last pairs around 10 years ago because no one was buying them anymore. So basically, if the installed springs are fcked up after 30 years, i need to find used ones in a better condition, which, you can surely think already, is nearly impossible.
So we took the shock absorbers apart (which were pretty dead) and cleaned the springs:
Congrats! The springs look like the surface of the moon. Great. Luckily, just 10km way from my home, there is H&R Springs which had, back in 1990’s, TÜV-Approved lowering springs (-35mm) for the G100. i quickly prayed and wrote them, aaaand: there was a pair in stock! I picked them up only two days later for around 200€:
I now hope the 35mm HR’s will fit the rim/tyre combination the car came with, because Auchter + Beck ones only are declared as -30mm. I am confused at this, because the height in my car’s papers was after the installation of the Auchter + Beck corrected by 35mm… so we will see.
I ordered also new shock absorbers, a battery, fuel pump, timing belt + water pump, oil & fuel filters and brakes.
W H A T S _ U P _ N E X T ?
08th June 2021
If you buy a Daihatsu, you get free rust with it. The rusty points at the arches with the transparent stickers on it? I can stick a screwdriver througt, but that was to expect.
I have heard that the mounting points for the rear shock absorbers are often mission critical / dead on arrival, and so it was very exiting to remove the plastic covers:
I was so happy about that outcome, i expected a very worse condition at this.
About 10 Years of standing still in a dry garage or wherever. There are a few little rusty spots at the windows and doors, but nothing serious. the arches need some welding, it seems that all other spots can be done with grinding & priming.
Meanwhile, we demounted the engine and all that plastic covers to have a look at the timing Belt & water pump:
Both look surprisingly fresh and in a good condition - maybe at least the timing belt was changed before, but without a notice at the engine bay or so. The last sticker for timing belt change said 1998 at 89.000km. So no risks here, new pump & belt.
I never changed a timing belt before, there are a mark at the top of the engine at 12 o clock and a mark at 5 o clock at the bottom - and my simple, but wrong thoughts was to adjust the marks in the upper and lower gear with the marks in the engine block - which is totally wrong.
When the mark of the upper gear is at 12 o clock, the mark of the lower gear is at 11 o clock, which makes no sense to me.
Fortunately, there are still some active people at the german Daihatsu forum an one of them send me a scan of an old manual:
Well, the ‘F’ is for ‘up’ for adjusting with the mark in the engine block & the mark in the gear has to be adjusted with the gasket line.
Yeah, that makes totally sense - but not for me. But i am no mechanic, so if this works, who cares.
So, the mailman brings me a lot of spare parts:
timing belt, tension pully, water pump, oil- & fuel filter and a new fuel pump in case the old one (which is not that old, around one year ago it was already changed) is dead again.
I also ordered both front and rear brakes, new dust protection kit and four new gas-pressure shock absorbers - after all i got three absorbers & no rear brakes.
But hey, it could have been worse! The seller told me he didn’t find the fourth in his warehouse, even if his IT-system told him there were only one of each in stock. Due to the fact that nobody bought rear brakes for the G100/102 in the last 2 years, he has to order a new pair first before he can send it to me.
I can understand this - its a 30 y/o car and quite rare on german streets. If i soon get the missing parts, i am a happy person.
Meanwhile in germany:
i’ve got copys of assessment papers / certificates for the seat & seat console, the rims and the lowering springs - only 48 sheets of paper to hand out to the TÜV engineer. All i need now are papers for the spacers & the tyres. Usually, you don’t need tyre approvals, but when you want to mount a narrow tyre on a wide rim, the tyre’s manufacturer maybe can give you a tyre approval - in my case for 185/55 R15 tyres to moun on a 7" rim.
09th June 2021
And today i ripped off the screw on the fuel tube. Aaaand the new water pump is DOA, i have enough today. I want to wash this car with rust remover. The Subfloor doesn’t look that bad at first sight.
Tomorrow we will remove the fuel tank & have a look at the fuel pump and the cables for it.
Hopefully, the new water pump will arrive until the weekend.
There is a little screw on my rust.
The fuel lines are pretty dead, rusted through and wet at some points. We will change the metal fuel lines for polyamide, so no rust ever again (on the fuel lines :’)).
  1. June 2021
So, tank is removed and need to be cleaned, many parts are clogged. there was 9year old fuel inside (or nearly 9). With the Colour of dirty apple juice and the smell of - i dont know, never smelled this before :smiley:
But hey, i had never thought that the sound of a working fuel pump could make me this happy. Rear brakes also arrived this morning.
12.06.2021
For today:
We cleaned the tank, removed the rust & give it a new painting. The reassembly turned out to be painful, there is so little space, the tubes are so short or stiff and to remove the tank was the hardest thing yet. But this is maybe an easier job when you don’t work on your parking lot, crawling through dust and sand under your new old car.
The new pump is mounted in the tank & we also have installed the new springs in the rear shock absorbers and renewed the dust protectors.
Hopefully the front ones come in the next days.
  1. June 2021
Hello,
i apologize für the lack of updates -
we put the fuel tank back in the car (and i can tell you: working on the fuel system of this car is not funny. I’ve learned so much polish bad words from my neighbour. No space at all, even on ramps this shitbox seems so fucking low that i felt fat like a piece of butter).
On mounting this shitty tank on the fucking underbody of this shitbox of car one of the 14274 on the tank slip off and we did not noticed it. Well, at least until we added some fuel, than i was wondering why the fuck my shoes are wet.
Tank off, tank on (now with correct tubing), add some more fuel, started the car:
Congratulations, fuel tubes are leaking, so back on the ramps we found one part where was more rust than fuel tubes. Called my daihatsu dealer: fuel tubes not longer available because old car (“where did you find this car?”). Ordered some polyamide tubing plastic pipe shit thingy thing which can be used for fuel tubing. removed the damaged part, changed it for polyamide, started the car: the fuel tubes leaked no more. At least at this point. 20 centimetres near this point we have now a waterfall of fuel. fuck you car. And fuck you, rust. Next we’ll change the whole tubing. 20metres of polyamide costs around 50€, so this is ok.
By the way, the car has new springs & shock absorbers. Old ones was -30mm, new ones are -35mm, but now its higher than before. maybe this will change in the future.
I accidentally bought a aftermarked muffler (Magnaflow MF6) from ebay. They are not meant to use with Daihatsu, but i was like “I have to have that”.
Things i learned today: some things look much smaller on ebay:
“Oh my god its so big” (thats what she said)
Looked nice imho, but there is not enough space for the muffler at the rear axle. Maybe if we cut the rear bumper a bit.
Oh, and the the new(!) fuel pump died again, we have changed the pump & cables 3 weeks ago or so.
So i change my Cars Name from “Krömer” (all my cars have personal names) to “Kursed Krömer” with a kool k. Just because it seems to be cursed.
  1. July 2021:
+1 Safety for Schroth safety belts.
Welcome. Absolutely fantastic write up. Greart Dai. Looking forward to hearing the progress.
Thank you! I have nearly two weeks of vacation now. The plan is to have this car back on street before this ends.
Great write up! I will be following your build :slight_smile:
I am very happy to read this, thank you.
Updated start post//
i have added ‘whats up next/08.06.2021’ section.
More Updates: Rust, Paperwork, Spare parts
More Updates :slight_smile:
if you just do the new updates in a post like your New updates post then it will come up as the next post that we are all taken to and we will see it is your update without having to scroll back up to find it. (just a suggestion work it how you like).
Keep up the great work :slight_smile:
Then I’ll post new things happened continous here & edit them above, too :smiley:
For today:
Hello Partypeople - sorry for the delay, i’ll add some updates tomorrow.
Hello,
  1. July 2021:
Hey Partypeople -
today we changed the rusty original fuel tubes with rubber tubes & changed the fuel filter.
The pump works sometimes, sometimes not. We guess that there are damaged cables.
gotta love the joys of working on 30 year old cars :confused:
I would work on those than a modern car any day of the week. Yes allot of old stuff will break but there is less stuff t break :wink: also allot more room is available + they are build to be repaired.
Anyone mentioned breaking old things?
The housing of the thermostate is fcked up, i ordered a new (used) one from a scrapyard, hope it will arrive next week.
But there are some good news:
The fuel tubes don’t leak anymore, we put new brakes on and changed the stabilizer bars at the rear. I don’t know the english word, those small thingy things with two rubbers on them.
Also fixed the fuel pump problem: there was a loose contact at the + pole. Working on the fuel system is the unfunniest part i thing, at least when your workshop is your parking lot. Besides the thermostate the only thing to do is four new tyres & some Rust removal. Then its going to TÜV/MOT and hope it will get an ok.
We also did an cavity sealing with fat/wax to prevent it from rusting.
Without rust holes the whole car looks Better .
Hello again, a friend was able to fix the thermostate housing with some sort of glue. I dont know what this stuff is made from, but it works. The spare part wont arrive until now, so we just gave it a chance.
After changing the coolant, thermostate & thermostate housing, we were a bit worried because the temperature was rising above 12 o clock on the water temperature meter gauge thing. You know what i mean. But it came out fine. The new thermostate opens at 84 degree celsius, the engine does not run hot anymore, and a little test drive prove this. So, tomorrow i will order a set of new tyres and then, end of the week, we will have a try on MOT / technical check, call it whatever you want.
you would be surprised what glue can do. A few years ago I broke down in my old xtrail @Luke’s place. The top plastic radiator tank split about 3 inches. Luke and I went to the local hardware store, got some 2 part epoxy some dishcloths and some bits to mix it, and some clamps.
We clamped the radiator to close the split then put some epoxy on the parts and then some cut-up bits of dishcloth and more epoxy so it resembled a fiberglass style look.
Then waited till it dried.
It worked so well I could hardly believe it. While the head gasket was stuff the car would still run no worries. The radiator was pressurizing and coolant/water was going straight out the exhaust and not one leak or buldge from the radiator. It held so strong I was super impressed.
The car on the other hand. It had to be towed and I later sold it coolant was just running out the exhaust so fast I would never have made the 1hr drive home.
But that was such a lesson on what glue can do.
