ED20 gearbox on EJDE engine?
Does a ED 5speed gearbox fit on a EJDE?
yes it is how 99% of the L200 ejde conversions are done. use the ed flywheel and clutch. efel also fits.
I meant I have ejde gearbox want it be short ratio
So you have an ejde gearbox and you want to put an ed20 gearbox on instead? As I stated the ed gearbox’x and the efel gear box’s will fit an ejde engine. You have to use the flywheel and clutch from the ed/efel gearbox. for them to work and possibly the starter. The difference also is Ejde style gearbox uses linkage for gear selection and ed/efel use cable. Also clutch lever on gearbox is in a different place.
I have read this topic. I guess the M100 sirion box is shorter and a straight fit?
how about the Move gearbox?
ed20 is a move gearbox in australia anyway
ok because in EU the move also came with EJDE
yeh we only got the ed20 in moves here. I helped @b_hoves put an ejde in his old move years ago.
I think, he was referring to second generation MOVEs using EJs. Unless, he means Perodua MOVEs which are the continuation of Japanese 1st generation MOVEs
