L701 Daily Build
Hey guys/gals this is my new daily driver
Mettalic blue, 2002 year, 173 000 km
Has some hidden rust issues but its ok for the time being
Looks clean all except the rear boot…
This is when I got it:
After driving it a few days some issues were found,
Left cv joint is probably bad, clutch (throw out bearing is ringing a little), need to check bushings on the rear axle, noisy gearbox (not like my old one…)…
Also tried some vw steelies with 185/60/14 tires from my ex mazda demio mini wagon… Rears rubbed on the axle so I put some 6mm spacers that i had around, it cleared barely… Fronts were ok but stick out about 10mm.
There is almost no rubbing when i am alone, but when i drive with a passenger its a different story hahah
It looks awesome to me as i love small wheels and meaty tires, but its too wide and i dont want to roll the fender lip.
Will probably go with 165/65/14 or 165/70/14.
Maybe I should get some of those rubber stoppers for the springs to stiffen it up a little, also dont want to lower it on springs its perfect to me like this.
[quote=“DRU, post:1, topic:5847”]…noisy gearbox (not like my old one…)…[/quote] I would inspect the oil level, immediately.
CV Joint damage is common with these vehicles. It is advisable to inspect these frequently. Once debris enters the joint, the damage caused will be irreversable.
On my previous Daihatsu, I replaced the gearbox oil with that of the fully-synthetic type. Afterwards, it didn’t shift so difficultly as with the old oil.
If you live further away from the Croatian coast, you shouldn’t be having continued rust damage problems.
When I last visited Croatia, I saw the built under license in Slovenia version of the Renault 4. Sometimes, I would see one in new condition. How much does a good one cost, these days?
Im in central istria so 30km away from sea and not on the continent so also no snow. I already bought cv joints for my other cuore so hope they fit. Ill change gearbox oil asap!
Renault 4 have got realy expensive around these parts, “clean” examples go for 2000-2500 euro minimum, they are popular with hunters and younger people like them as a retro ride and utility car that their grandpa drove.
I was afraid of that. When one waits too long for buying one, the prices can only increase. Especially, after joining the EU where importing them here is no longer a bureaucratic problem. I imagine that they’re not so expensive in Croatia and even less expensive in Serbia.
If your older Cuore is also a 701, there shouldn’t be any problems in replacing the CV-joint with the one of which you bought, unless the Cuore of which you are now driving has an ABS-controlled braking system. The outter joints of an older non-ABS vehicle will not work with this system. However, if the replacement CV-joint was manufactured for an ABS system, it will function in a non-ABS-assisted vehicle
Thanks for the cv info!
Yeah old cars are getting expensive, but in croatia median pay is lower so money from western europe can buy more here, and people like to haggle alot (I personally HATE it) so the asking price is high from the start…
One other thing bothering me is the steering ratio… Its so too much… Im looking at steering quickeners lol
Got some new wheels, bbs ra’s 13x5.5
Oh man they will look great in combination with the blue! Maybe some less baloon-y tires? :slight_smile:
I like em a bit chunky lol
Tires are good, also size fits ok as it fills the arch and helps with bumpy roads.
When I redo the suspension, will probably get some lowering springs ~30mm max…
looks good mate!
They look awesome. I really like the color :slight_smile:
Wanted a tach gauge since i got it, and finally found a nice cluster on german ebay. Its from a m1 sirion with an ej-de engine. After some fidling it was mocked up and tested, it worked ok, and before final assembly I removed the abs light as my car has none (it was on after the car was running)
One thing that is strange is that the fuel level is a bit lower, hope it works ok…
Cuore was sitting in my garage since 10/2022 when registration expired, bought myself a 2004 civic 5door, as a bigger everyday car was needed…
Now its time to register it again and have some fun with it.
Some parts were collected and some mods were done and more will be done after the rego, as not all will be legal - no tuv for lowering springs :cry:
First mod was a diy short shifter, as I have a second parts car, its gear stick was removed and modified, was planning on welding an extension but as it turns out this was not needed…
All that was done is I filed another flat spot for the plastic ball ring 20mm higher on the stick, also straightened the two curves of the stick a bit.
What is great with this mod is thats reversible from the inside, no need to remove the gear stick and lever from under the car.
One thing to note is that the bushing for the side to side motion needs to be replaced…
Refreshed a set of 15" steelies from a mini, maybe will try them on after registration with some new rubber, 165/50-15 like on copen iirc
Well after that tried fitting the copen swaybar but my dumb as* forgot that I need the k-frame :sob:
Passed inspection with no fails or remarks, was suprised tbh…
Well Done Mate !
Installed clear side indicators from a micra k12, as seen on @Blyatsu build thread :ok_hand:
Changed the springs with ta technics, not much lowered, maybe 30mm but handling is much improved, it just needs a rear swaybar and its done, still waiting for tires for the 15" wheels…
Also restored an old steering wheel found localy, its probably from the legendary tuner days, sex spec as its called in aus :joy:
Steering wheel installed with a hkbsports boss kit (od234) for copen, perfect fit.
It is a bit smaller than stock, 320mm, works great!
Next mod will probably be to fit some first gen smart car seats, I got them for 50euros, they are a lot lower, about 80mm.
Next to them you can see opel corsa b 13" wheels, this will be the winter setup, they need a sandblast and paintjob.
At buddy’s drift trike track :joy:
15’s fit good :ok_hand:
Started with the seats, done a few of these swaps before, its not been easy this time, a lot of staring and swearing, fitted the drivers side half way but it got dark so no pictures atm
Drivers side is ~65mm lower, passenger side ~40mm
Needs a deep cleaning, drivers has some damn gum…
