Mate, I am. But at the moment I don’t know when I get to drive it as it needs to be complied and have all the broken, worn or leaking items replaced. I can see it already needs tie rod ends and a cam cover gasket.
On the way home cruising at 100km/h there was a little dip in rpms and the engine became sluggish. I pulled over and saw water on the ground, my heart skipped a beat but it was just the aircon. The engine was pretty hot but i saw no obvious signs of trouble. The temp guage was normal and the oil light wasn’t on. I nursed it home and put it to bed as it was nearling 10pm. Next day i pulled the front end off to get to the turbo as something told me to investigate that. I was right, turns out the compressor bearings had collapsed and the compressor wheel jammed itself into the housing seizing the whole thing.
I was set to get a local turbocharger builder to rebuild it and also high flow it but in the end he couldn’t get a hold of the smaller components. So we ended up having a second hand low km one from a JBJL in a L6 SRXX Move in Japan shipped over. We found it very hard to get a TRXX Mira one as there are a few different turbine housing bolt patterns for the dump pipe, but the Move one was identical even though the turbo specs are slightly different.
Since then I’ve just been dailying it but a few things are now requiring maintenance.
I’ve had to replace the original battery it came with and I also removed and sold the roof racks to a guy that wanted to carry surf boards on his L5.
A few things I’ve ordered so far are hub side CV joints with boots, gearbox side boots for the CVs, gearbox oil seals for the axles, injector repair kit, cam cover gasket, spark plug oil seals, distributor block shaft oil O ring, steering rack ends, tie rod ends, PCV valve oil seal grommet, lower control arms and two new Nankang tyres.
I’m not looking forward to doing most of it after having done alot of the same things on my previous green L5.
good to hear she is alive and kicking and looks great too.
The maintenance stuff is a pain but at least you know how to do everything especially having done it before.
Great to see an update
So September 2022 it was put in storage at work due to an unknown engine problem where it seemed it had lost compression somewhere. A few months later the cam cover came off and it looked like it had bent a single intake valve in cylinder two. Sometime earlier this year I managed to remove the head, my first ever one. It wasn’t a bent valve but half of the injector pintel cover had broken off and jamed between the head and intake valve keeping it open.
Well after lots of face cleaning and reseating of two intake valves the head went back on today. We ended up snapping one camshaft cap bolt but it was sticking out enough to remove with some needle nose pliers. We finished up the day wondering how to get the camshaft timing sprocket back onto the camshaft. It was zipped tied to the chain and never fell down but it’s about half a centremetre off being able to slide onto the camshaft. Anyone have any ideas about this dilema?
