I finally finished Frankensteining both systems.
I repaced the oxygen’s operating pressure guage with that of the newer set and scraped the plastic lens of the other guage, in order to make its contents visible. My plan was to swap that guage also. But, was afraid of breaking it off, because of how tight its screwed in. I might try a second attempt, when I’m not dependent on this torch. This guage is of secondary importance, because it only shows how much gas is still available.
When I bought this set, the cart came with it, after I’ve converted this abandoned one into a cart for carrying 10 litre tanks. The cart which was manufactured for the smaller tanks has smaller thin wheels which are fine for a paved shop floor. Since I’m working outdoors and am storing these in a room that has cobble stone floors, I needed a cart which was easier to roll. Hence, converting this larger-wheeled cart into a carrier for smaller bottles
Shortening both hoses may have been a mistake, seemingly underestimating its length, once I started using the torch. After turning the acetylene valve open, gas came out sooner than expected, meaning that i wasn’t losing gas in vain, to the amount expected when the hoses would have remained in their original lengths. It matters little, because I kept the nearly new hoses that came with the tanks.
Because the oxygen’s hose is getting old and brittle, I ended up needing to retighten its hose clamp a couple times
Because the tanks are considerably shorter than the 10 litre ones I rented, I needed to cut off the cart’s upper brace, as pointed to by these arrows and can be better seen in the upper-most posted image, so that I could turn the regulators to face the handles, preventing damage to them, if the cart were to fall forwards
Having been used to working with pressures measured in lbs. per square inch, it took time to adjust to Bar per cubic meter readings.
When I last used a torch, my eye sight was still good enough for using only tinted brazing goggles. Because you can’t get these in prescription issue (that I know of), I’ll have to somehow attach a pair of lenses within the goggles I have
