Copen brakes next on the list, then we’ll see how the 14 inch wheels fit over them. Test fit indicated that they will juuuuuust fit, but I’m not 100% sure. I have copen wheels, which I plan to fit once I have the right tyres, but if the 14s don’t fit it might force my hand.
Also, cosmetic update, thanks to @Mr_Gormsby I had a black bonnet. I chucked that on too.
Bit of a set back today.
I got everything tightened up and was getting ready to get the front end back on the ground. I spun the drivers side just to make sure it was all good and found that it wobbled a bit. I grabbed it and gave it a wiggle. Bearing is shot I think. So, drivers side is going to come apart again . I really should’ve check it. Oh well.
New one ordered. I’ll get my father-in-law’s workshop to press it in.
Just frustrated for the delay.
Edit: I did get a chance to order a few more things from Japan. First is a leather momo steering wheel from a l150 Move. It will be a straight fit.
Make sure the axle nut is tightened all the way! I believe these are conical/tapered bearings that need preload, otherwise they’ll have play (don’t ask me how I know)
Good luck!
1st thing. I checked the axel nut, it was tight, so it’s definitely the bearing. The bearing was delivered today, so I’ll get it pressed tomorrow at my Father-in-law’s work.
To keep my self busy, I’ve been replacing interior clips and screws that have broken or disappeared.
I’ve also been working on my intake:
Just waiting on one more silicone joiner to arrive.
For the intake temp sensor, I have drilled a hole tucked at the back and put a rubber grommet in, then in she goes.
